Results 1 to 10 of 18
    Cheshire
    51
    331
    Pilgrim Sumo (Kittihawk) Build Diary
    I've scanned the build diary that the original builder, Max, wrote for the Pilgrim Owner's Club and that came in the box of documents with Kittihawk.
    I've used OCR to get it into a format I can easily post so please forgive any typos. I'm going to post a new installment every week or so.
    Sumo MKIII Build Up Report
    Part One
    IN THE BEGINNING
    For many years I have been one the many people dreaming about building my own car. I even closely researched the subject a few years ago but decided that money was a definite problem. Changes over the past year meant that in the spring of '93 I was again researching the possibility of a kit build.
    My requirements were simple. I had to want to build and drive the car. Sounds easy. I have had the normal home mechanic experience, so parts of the build would be alright, other parts frighten me silly! (How do you make brake lines?) I needed a one donor kit, or as close as possible. I had to be able to drive it - out go the Seven's (too tight for comfort). Of course money came into it - I didn't have enough!
    In the end I was down to three possibilities, one of which was the Sumo. My father became interested at this stage and a partnership was struck. We visited Den together and inspected the Mark III Sumo. We were happy with Den's commitment and with the design. We were however nervous about being one of the first to build a Mark III Sumo. Lots of discussion later, the decision was reached, and the order placed for a pilgrim Sumo Mark III.
    THE PLAN
    The car will be based on a 2 litre sierra. We decided on a red gel coat finish. We intend to fit a 5 speed gearbox and a standard carburetted 2 litre pinto engine. Problem - all the MkIII's Den has sold have been Rover V8 based. We are the only customers building a pinto powered version. Never mind, it can't be that bad!
    I had three weeks holiday booked for September and planned to devote them all to the build. The idea being that a good start could be made, thereby keeping enthusiasm high. The kit delivery date was set for the beginning of the second week of september. I joined P.O.C at the Sanddown show while sussing out other builders.
    My parents went on holiday and I had four weeks to find a donor and arrange things! The dream starts to become reality.
    THE DONOR
    After two weeks I managed to find a 1982 Sierra 2.0GL with a 5 speed gearbox. It had a current MOT, done under 80,000 miles, had no body damage, only a small amount of rust and looked well looked after. A deal was struck and I was now the proud owner of a donor car.
    I got it insured and covered about 300 miles in the following fortnight. A few faults showed up - it never warmed up for one. A replacement thermostat and viscous fan unit sorted that and when we took it off the road, we were sure everything that we wanted worked. Its MOT still had a week to run!
    THE FIRST WEEK
    The first task was to empty my fathers double garage, or rather rearrange it. The garage was emptied of cars, bikes, lawn mower and the rest rearranged to give more space. An engine hoist was borrowed from James (very useful knowledgeable friend built Duttons, custom minis, rebuilt TR6 etc) along with a few other tools and the Sierra moved into position.
    Out came the engine and gearbox - wow that was quite easy!. with the Sierra bodyshell positioned in the drive everything else was removed in the next three days. The rest of the week was occupied with cleaning, stripping, painting and reassembling the parts we intended to use.
    The engine was in good nick, as was the gearbox. The clutch was replaced, and the whole reassembled. We had passed the first hurdle - never done a clutch before, hope it works OK!
    All the ancillaries (pedals, servo, diff, wishbones, hubs, wiring loom etc) was cleaned and stacked away in boxes. I was particularly careful with the loom and labelled everything before I unplugged it!
    The garage was tidied (again!) and the area swept and half carpeted ready to receive the body and chassis.
    What have I done? will it ever work? Should I put the Sierra together again and sell it? (Fathers suggestion) Where has all my money gone? Am I mad? (my mum thinks so)
    to be continued
    2,954
    this is a good read - like a trip back in time
    9,578
    How about a series of articles for the club mag ?
    9,063
    what Martin said!
    Cheshire
    51
    331
    Instead of here or as well as?
    9,578
    Both if that's OK with you. There are a lot of people in the Club that would love to read this sort of thing that don't visit this site. Plus there is no limit to pictures you can post on here.
    Oxfordshire
    68
    1,683
    Just one point - from what you said in the first post, the original builder produced the build diary for the Pilgrim Owners Club. This suggests he should have no issue with it being reproduced elsewhere but, if you haven't already done so, it would be courteous to seek his permission before doing so.
    Alan
    Dax 427 DeDion - SOLD
    Cheshire
    51
    331
    Quote Originally Posted by conrod View Post
    I did and he doesn't have a problem with it
    Cheshire
    51
    331
    I can certainly do that. I signed up to the club last week and I'm just waiting for my membership number for my insurance.
    10,061
    Mathew you have a PM.
    In build- Hawk 289 Sebring
