    Jun 2005
    Norton Cross
    524
    Finishing door seal near dash
    What’s the best way to finish the door seal on an AK where it meets the dash? If cut off to edge, does it pass iva?
    Pete
    8,529
    I tucked mine behind the dash.
    Mar 2010
    Highlands (North of Inverness)
    1,243
    I used Sugaru.
    Best anti speeding device - a rear view mirror with a police car in it.
    A pedestrian - someone who thought there was still a couple of gallons in the tank.
    AK Chassis and body collected 12.12.14
    Feb 2003
    SHRIPNEY VILLAGE, SUSSEX, U.K..
    1,060
    I thought that was what the Australians put in there tea.
    Frank Dowsett. BLOKE
    Mar 2010
    1,243
    For those that have not used Sugaru before it is as it states, a maluable putty like adhesive. I made sure that I poked some down the open end of the rubber section and then simply moulded it to form hardish rubber end cap. It is really easy to get it looking nice and smooth with a little bit of water or spit on a small flat blade.
    I'll post some images later.
    Cheers.
    Paul.
    44
    2,305
    I cut mine off square and used CT1 sealant to seal the end as neat as possible.
    4,053
    Quote Originally Posted by Highlander View Post
    Cheers.
    Paul.
    I've used it to repair cables (Apple, mostly!) and the like before now - hadn't considered that as a use, but can second it being very easy to work with and get looking professional*
    *or on the first cable I tried it on.. just about passable
    Mar 2010
    1,243
    Sorry for the delay, here are the pictures of my door seals. Somehow the pictures don’t make them look as good as they do in reality
    Nov 2006
    Shropshire/Wales Border
    5,955
    Lloyd B
    Current: Crendon #54 in build - 427 Side Oiler/Cobrajet Heads/Dual 600cfm Holleys/4 speed toploader/Vintage cast knock on wheels
    Dedion Dax/Clarkson 383 Chevy with roller 4/7 swap cam, AFR195 heads - SOLD
