    Apr 2006
    Glasgow
    225
    ignition wiring plug
    Hi can anyone tell my the wiring for the ignition plug to the jag steering column on a Mk 3 cobra. Cant find the original wiring diaphragm put it somewhere safe Haha
    cheers james
    GD 427 euro LS1 Magnum T56 (sweet)
    Perth
    4,544
    I don't know if this is any help, but this is from the Haynes manual.
    Cheers, Clive
    Apr 2006
    Glasgow
    225
    Thanks GD use different colours but should manage to check voltages to prove correct. Jag switch worked fine for years change to modern switch on the dash and it couldn't take the current . Should of left it alone !! Haha
    cheers james
    Mar 2008
    Coventry
    2,233
    Quote Originally Posted by jamesLS7 View Post
    cheers james
    The switch you installed needs to power a relay to power the starter then your switch will be fine.
    AK, on the road Oct 2012
    Apr 2006
    Glasgow
    225
    Hi Definitely going to relay the primary power switch so the ignition switch should only be pulling an amp. Also managed to get a Lucas switch which should be better quality than the fried switch, sold as quality but opened it up and junk internals.
    cheers james
