Page 10 of 10 FirstFirst ... 8910
Results 91 to 95 of 95
  1. #91
    Aug 2002
    Through the Darien Gap
    1,038
    Quote Originally Posted by conrod View Post
    They're being sold under the EasySteer name:
    http://simonebirchall.co.uk/controll...sensitive.html
    That's the one. Good to see it's still available. A good bit of kit.
    Steve Brown
  2. #92
    4,141
    Quote Originally Posted by route66 View Post
    Have the same box of tricks here - the only bad thing about it (I can't say what it's like to drive with yet) is that the box is so huge!
  3. #93
    1,178
    Looks like 5 x 3 1/2 so about the size of the ECU ?
    I heard the same about the steering not feeling as good at speed with the Corsa EPAS .
    Also the column has to be fully weather proofed cowling cover as any water into the steering column control unit can cause the steering to have a mind of its own and go to full lock! The conversation was with someone who jet washed his car and the steering went to full lock as water had entered into the steering column. He as jet washing the interior though .
  4. #94
    Feb 2013
    291
    Introducing (probably) the world's first de-modded, Corsa B, NON-EPAS steering equipped Dax Cobra! Yes, I've done it. It only took me a couple of hours to remove the EPAS upper column, swap the Dax mounting bracket, swap the plastic top bearing housing over and bolt it in. Much better. The EPAS only improves parking. Once on the move, it simply removes feedback. If you switch it off, you then feel the motor and gearbox dragging behind.
    I'm much happier with heavier parking but live steering. And SO easy to fit. If you are even considering this de-mod, start looking for a non-EPAS column now - because they don't come up often.
    I've removed it again and made an easy mod to the lower mount and bolted it to the Dax bracket. Just need to fit it back in tomorrow and that's it.
    Some photos...
  5. #95
    Hilperton,Wiltshire
    2,595
    Good luck with the removal of the EPAS from a Dax EPAS equipped owner. 9 years without, 3 years with and it's not being removed. Everyone is different.
