Results 1 to 10 of 11
    Nov 2004
    174
    Pro Comp Electronics control box issues
    Hi Guys,
    I have a Ford 351c in my RAM and ever since the engine conversion I've experienced hesitation on part throttle and a mis-fire at the upper rev range. I've spent ages fiddling with the carb (Holley 670 VS), adjusted the pump settings, increased the pump volume, increased the power valve size, changed both primary and secondary fuel nozzle sizes, all to no avail. I started to alter the distributor timing and things seem to be improving, not enough though. I've heard stories of this MSD copy as being rubbish, has anyone had any first hand experience? The engine conversion and setting up initially was done by Thunder Road Cars and Cheng was baffled as to why these symptoms should exist after he'd checked everything when he put the engine in. I've spent 2 years trying to locate the problem and only now started to wonder if this "cheap" MSD copy system could actually be the problem. I replaced the Pro Comp billet distributor before the engine was started with a genuine MSD billet unit, although I kept the control box and coil pack.
    Any comments would be appreciated.
    Ian
    2,756
    Would it be worth seeing if Cheng has a spare proper MSD unit he could lend or do some testing with?
    I had an issue a few years ago, with RPM related issues with my MSD unit (spluttering and stuttering at 4k RPM or higher), turns out my MSD unit was a copy of an MSD unit - the serial number of the unit matched the serial number of the photograph on the original and genuine MSD box. A google search or two later found a number of threads regarding dodgy MSD units with a particular serial number - yep you guessed - exactly the same as mine. Had to buy new MSD unit but issue was fixed.
    rgds
    Gary
    Nov 2004
    174
    Thank you Gary for your prompt reply and confirmation of my thoughts. I'll replace the control system and coil for MSD products and hope this is the end of my quest.
    Best regards
    Ian
    556
    This was a about the 6-AL not sure if you have this version ?
    https://bangshift.com/general-news/s...ion-vs-a-fake/
    Nov 2004
    174
    No it was a pro comp version of a MSD 6 unit, no rev control available.
    8,122
    I had problems with an Accel unit that does the same thing as above - lots of backfires and terrible timing behaviour..This, I believe, was mainly due to the method of installation, as I think Mike Huddart gave me the wrong diagram to implement in my loom. Either that, or it was a faulty unit. Engine sounded terrible.
    Once I cut out the ignition box from the ignition circuit and just used the dizzy to fire the coil the engine has sounded so much better.....after it was re-timed using a vac gauge.
    Nov 2004
    174
    Certainly food for thought, it all seems to point in the same direction. The control box/wiring is where I need to look further at. The car starts first time and idles well, it just stumbles on part throttle initially and then mis-fires at the upper rev ranges. Overall I am loosing power and not getting the most out of the car, hence why I thought I'd ask for fresh minds to confirm or deny if I'm on the right track.
    Many thanks for your input
    Nov 2004
    174
    Update. Issue solved, don't buy cheap rubbish. I replaced the system with a genuine MSD 6AL box and blaster coil and my problems have all but gone. I just need to re do the timing slightly because it is a little out, otherwise there are no more of the previous issues. 2 years later and a lot of fiddling, finally I can have some real fun now. Happy days! Thank you again to all those that offered advice, between you all the mystery was narrowed down to the ignition control box.
    556
    Glad you sorted out your problem . MSD boxes are good units and you can also open up the spark gap to improve things unless you want to switch back. Also mount the unit with the supplied rubber feet to stop vibration and make sure your cables are routed away from the heat sources like exhaust . The timing can be advanced but be careful not to much as MSD deliver a spark over a longer duration .
    2,756
    And the MSD will fire through this too - lol
    This was one of the results of the problems i was having with my engine (all 8 would be like this on new set of plugs after 10 mile drive) - thankfully all now sorted
    Gary
