Results 11 to 14 of 14
    Oct 2013
    southampton
    79
    Non insulated, crimped, soldered (leaded if you can get it ) then heat shrink sleaving . Takes a bit longer but proper job.
    9,070
    With a proper crimp tool they make excellent connections.
    But as to the OPs post: ebay is your friend, and always buy x2 more than you need - you will use them somewhere - and avoid paying halford's silly prices.
    May 2003
    Hampshire
    114
    Soldering a ‘good’ crimped joint actually produces a inferior joint as it produces a stress raiser where the solder wicks up in the wire. Under vibration, a soldered crimp will break at the extremities of the solder, the longevity of the joint will be down to the support given by heatsrink and also support of the harness/wire. Getting a ‘good’ crimped joint is an issue if the crimp is pre-insulated or the tooling is not up to it.
    soldering a badly crimped joint is likely to improve the joint as the failure mechanism will likely be a poor electrical joint, ie open circuit or resistance increase, which the solder will improve.
    I work for an aerospace company that manufactures electrical harnesses that are used on aero engines, so it’s a harsh environment- joints are crimped only. In the past, company also made in-tank aero fuel gauging harnesses, again crimp only.
    Like others have said, get a good tool, use non insulated crimps, crimp only and then insulate after crimping and support well.
    Roger
    RamSC 351 Cleveland
    on the road 8 years- nearly finished
    Nov 2016
    Stevenage
    315
    Yup been crimping in my job for 22 years, dont like them outside the cockpit though, the aluminium can corrode. I solder on brass ring terms or even stainless for the earths
    Supplier Beale.co.uk. For general public
    I have other suppliers for trade prces on quantities.
    Graham
