Results 1 to 8 of 8
    Apr 2007
    Swansea. South Wales
    526
    Bonnet bump stops
    Hi guys
    Ive seen a few pics where around the bonnet lip there are rubber buttons
    Just wondering which ones you used and where you got them from.
    Matt
    May 2011
    Flimwell
    807
    I didn’t want to drill any holes before paint do used something like these
    https://rover.ebay.com/rover/0/0/0?m...2F222387777749
    You can easily find different sizes on eBay.
    So cheap it makes sense to try them out.
    Feb 2013
    265
    Wilko. General purpose sticky pads.
    Apr 2007
    526
    Cheers guys ill give em a go
    Matt
    Feb 2003
    1,060
    I see a problem with the above comments, you will be creating a gap between bonnet, and body, this will allow water to flood in,
    I used a conventional rubber strip made for the job, its like a rubber tube, with a flat area to stick it on to the body, mine is about 10 mi. deep, but check you own gap, and is continues all around the bonnet, use rubber around 2 mil. bigger so It seals on closing, also it gives you a much better feel when closing.
    Frank Dowsett. BLOKE
    Apr 2007
    526
    thats an idea
    thanks
    matt
    Nov 2016
    Stevenage
    280
    Water not to get in is a good idea, same time the rubber buttons allows a bit of breathing on a hot under bonnet,
    Either/or really.
    Feb 2003
    1,060
    Scoop, and side exit panels give adequate cooling, I run a Ford 351 Windsor in my Roadcraft, 50 % distilled water, 50% antifreeze, and have not topped up in three years, and it is as clear as the day I put it in, I have a large expansion tank supplied by GD, and until I fitted it I had to top up quite often.
    Frank Dowsett. BLOKE,
