Results 1 to 3 of 3
    Jul 2002
    Curridge, Berkshire
    885
    Indicator wiring issues
    Hoping someone can point me in right direction.
    Can anyone explain what the potential issues could be that would cause the following.
    Indicators all work properly on hazard switch but none come on at all when using indicator switch to either left or right.
    I swapped out the switches and that hasn’t solved the issue so doesn’t look like it’s the switches.
    (Standard Dax loom in this case).
    Thanks for the help
    James
    DB134, Blue and White of course, Huddart 383 SBC, MSEfi, EPS and all things gay.
    May 2011
    Flimwell
    835
    The hazard warning lights are fed by a different fuse (along with the horn & clock) from the stalk. Sound like it’s a positive supply issue.
    3,692
    Agreed! I had my pre mot run round and had indicators working but hazards were zilch (opposite scenario to you), I had blown a fuse that supplied the hazard switch with perm live, yours is probably a switched live fuse that has gone.
    Rgds
    GD J1M
