Results 1 to 10 of 21
    May 2014
    Cranleigh Surrey
    9
    Nylocks and copper grease
    Hi Everyone,
    I'm assembling the suspension on my AK and the instructions recommend using copper grease.
    However, on some components, nylock nuts are required. The question is; is it ok to use copper grease with nylocks?
    I'm concerned that the grease will reduce the friction between the nylon insert and the bolt thread making it less effective at preventing loosening.
    What do you think?
    Neil
    2,251
    It will be fine! The nylon does not prevent the nut from loosening, it prevents it from falling off and it will still work with a bit of grease on it.
    Marlow
    68
    1,734
    Hi, Of course nylocks prevent loosening, thats what they are designed to do!
    Jump to search
    Nyloc nut
    A nyloc nut, also referred to as a nylon-insert lock nut, polymer-insert lock nut, or elastic stop nut, is a kind of locknut with a nylon collar insert that resists turning.
    The plastic insert is placed at the end of the nut, with an inner diameter (ID) slightly smaller than the major diameter of the screw. The insert deforms elastically over the threads of the screw, without having threads in turn cut into it. The nylon insert locks the nut by friction against the screw under the applied radial compressive force. Nyloc nuts retain their locking ability up to 250 °F (121 °C).[1]
    Cheers Clive
    On On
    Mar 2014
    Marham
    233
    What Myles is saying is that the friction, along the bolt axis, between the male & female threads is what prevents a fastener coming loose, obviously this force can be overcome.
    As soon as the fastener comes away from the mounting surface the thread to thread friction is reduced to almost zero, this is where the nyloc comes in by creating a rotational friction.
    Grease will not affect the axial friction but will, slightly, reduce the rotational friction. So in a high vibration environment where failure is safety critical I would not use grease on a nyloc - But in those conditions I wouldn't used a nyloc I would lock wire.
    AK Gen II - Delivery May '15
    Maldon Essex
    242
    Agreed, IF the nylon band in the nut fails to stop it coming loose then how would it stop it falling off? The whole point of a Nyloc is to stop it loosening.
    But in answer to your question, I put mine together with a bit of copper ease and have had no problems, the nyloc will wipe off almost all the grease as you tighten it anyway.
    2,251
    Quote Originally Posted by Richie View Post
    Correct, a tiny band of nylon cannot possible stop a correctly tightened fastener from coming loose; the forces are simply too great. Once loose the rotational forces are relatively small and the nylon stops the nut from coming off completely. From a safety perspective I guess loose fastener is a lot better than no fastener.
    Marlow
    68
    1,734
    The answer to this question is in the name, it's a LOCKNUT, other wise you would need to place some other kind if locking devise on the fastner such as a Locking washer, or locktight, which you plainly don't have to.
    That's why so many critical items have them.
    Regards Clive
    On On
    Mar 2014
    Marham
    233
    That’s like saying a bulletproof vest is bulletproof!
    Anyway, yes copper grease will reduce friction between the thread and the nylon insert, yes the insert will wipe away the vast majority of the grease, yes a greased nyloc is better than a plain nut.
    With the vibration we’re likely to experience, use copper grease & nylocs, I did!
    Aug 2011
    341
    Where is the like button when you need it !
    May 2014
    Cranleigh Surrey
    9
    Many thanks for all the replies guys. I now won't worry too much if I get some grease on my nylocs
