Results 1 to 8 of 8
    Devon
    277
    Identifying front calliper XJ6
    Hi All
    I want to fit new front brake hoses to my Dax, is there a positive way of identifying the correct fitting for the new hoses without taking the old ones off?
    I presume it’s early series 1 or 2, not sure if they’re the same fitting.
    Geoff
    Oct 2006
    Toton, Nottinghamshire
    832
    Quote Originally Posted by Mitch View Post
    Hi All
    Geoff
    Geoff,
    If they are XJ-6/12/S calipers then they are normally Series 2 or 3 and most Cobra builders opted for the 4-piston Girling caliper. These can be metric or imperial threads. This web page may help..http://www.jag-lovers.org/xj-s/book/SSBrakeHoses.html
    There are a number of online specialist Jag parts suppliers. Most have pictures of the parts so you can compare with the hoses you are wishing to replace.
    Russ.
    1984 DAX Cobra
    Jul 2013
    Hertfordshire
    492
    Have you got a photo of them?
    Devon
    277
    Thanks Russ, I’m sure this has been gone over before, but just wondering if fitting braided hoses will make for a better pedal. There seems to be some controversy over the benefits.
    I fitted a new master cylinder recently but still have a long pedal, I’m going to fit a new resovoir which will enable me to use a pressure bleeder.
    It was suggested to fit some braided hoses as well while I’m at it.
    Anyone else have any opinions if they’re worth fitting?
    Marlow
    68
    1,745
    Hi Mitch, What is the controversy? I have never read of any? Braided hoses for me.
    Cheers Clive
    On On
    Devon
    277
    Hi Clive
    Have a look at the link in Russ’s reply, seems to sum up the alternative view.
    Nov 2016
    Stevenage
    194
    Early calipers on the 4 potsi think imperial brake pipe fitting thread. Later after early 1980’s i think metric. Also i did away with the link pipe and bracket and the bradeds (dax) screwed straight in with a compression copper washer
    Oct 2005
    Cape Town, RSA
    127
    This is an important part in the link provided, and not only for XJ6:
    "10mm x 1.0 is not the same as #3 AN. The thread on #3 AN is 3/8"-24, or standard 3/8" UNF. Needless to say, you do not want to mismatch threads on a brake system. Check very carefully, as these two are close enough you can actually screw them together."
    M10x1 won't fit into 3/8 UNF, but it fits the other way around - and will never work! M10x1 basically has a 25,4 TPI versus the 24 TPI of the 3/8 UNF.
    Beware of using a spanner to test. I have seen 3/8 UNF fittings with 10 mm spanner size.
    On a side note, there is a similar disaster lurking with M12x1,25 (20 TPI!) which is similar to 1/2" UNF (20 TPI)
    This is cruicial on caliper bolts and wheel nuts/studs!
    Nothing is as it seems...
