Results 11 to 16 of 16
Thread: Lock Wire
    Mar 2014
    Marham
    236
    I'm a licensed dog walker and Stella drinker, I've never fitted a lock wire to anything and I have two IVA badges on my swimming trunks.
    Not saying you need to fit it, but if you do and it's obviously wrong, you're inviting a closer, more sceptical look at everything else from Mr IVA.
    AK Gen II - Delivery May '15
    498
    Lockwire doesn't really stop fasteners coming loose, just stops them coming looser. Hopefully this would let you come to a safe stop before your brake caliper or rotor blade fell off.
    Don't see much in the way of lockwire on modern cars, most rely on loctite type stuff.
    Jul 2013
    Hertfordshire
    522
    Did you sew them on with 0.8mm lock wire?
    Aug 2016
    WELLINGBOROUGH
    119
    Can I put in an offering on the subject of lock wires, nyloc nuts and other devices.
    If you install a bolt, whether it is in a blind hole or with a nut, then if it is a 'critical' part being secured, a torque is generally required. This is either stated as a torque or maybe a bolt stretch length.
    If installed correctly, to the specified torque, nothing else should be necessary.
    If a nut and bolt system is used where there is a requirement to apply pressure to a part, as a form of adjustment or to compensate for wear, then the nut is normally restrained in some fashion. Most common is the castellated nut or a second nut (true lock nut).
    'Locking wire' does not and cannot 'lock' anything. It is only a retaining device. The same applies to nyloc nuts and any other device using friction.
    Logically, if the required torque cannot be applied by the wire or nyloc nut then it cannot possibly 'lock' the nut or bolt. The applied torque does the work. The wire or nyloc is only a restraining device.
    I have been an engineer ranging from nuclear submarines to commissioning plant in the oil industry.
    Sceptic
    Feb 2013
    311
    A correctly wirelocked fastener will only be able to move a tiny amount before the tension in the wire prevents it from turning any further. If the same fastener was not wirelocked, it will loosen. Very different to a nyloc, which will loosen until the turning force no longer has any purchase on the nut. I agree that it is a restraining device, but it is cable of keeping a torqued fastener tight.
    I disagree that a castellated nut is always used to apply pressure to a part, however. I can think of plenty of examples of a castellated or slotted nut being backed off to the next available slot before being pinned.
    Jan 2012
    Perth
    1,683
    Now that's just made my morning
    cheers
    AHP Crendon Chassis No 1
