Results 1 to 10 of 16
Thread: Lock Wire
    Billericay, Essex, England.
    870
    Lock Wire
    Simple question but can't find the answer anywhere.
    What size lock wire is used for diff mounting bolts, calipers etc??
    Many thanks
    Sean
    Feb 2013
    261
    I'd use at least 20 swg (0.036",0.914mm). You could go bigger,19 or 18 swg, but I think 20 swg is plenty strong enough.
    Mar 2014
    Marham
    236
    Aerospace standard is 0.8mm. That’s what I’ve used.
    AK Gen II - Delivery May '15
    870
    Thanks both for your feedback.
    I've measured what Dax have used when they installed the diff and it appears to be approx. 0.7mm.
    Think I'll step up slightly to around 0.8mm
    Now, 9" pliers or 6" pliers??
    Sean
    Sep 2014
    aberdeenshire Scotland
    220
    6" every time, much nicer to use, and that is backed up with 43 years as a Helicopter enginer.
    Shuggie
    870
    Perfect!
    Sean
    Oct 2005
    Cape Town, RSA
    127
    Don't worry too much about the wire diameter. The bolt is tight from torqueing it, the wire keeps you from losing it (as in turning out and dropping on the street) - not loosening it. I hope the heli engineer agrees with me, a Can Am mechanic of 20 years
    Nothing is as it seems...
    Mar 2014
    Marham
    236
    Quote Originally Posted by dominik View Post
    Please tell me you're joking???
    If the lockwire only stops you from losing the bolt then I'm afraid you've antilocked it! The lockwire should be tight enough to prevent the bolt moving.
    Hope the Helicopter engineer agrees with a 20 year fixed wing engineer?
    Feb 2013
    261
    I have to agree with Richie. I too am a licensed aircraft engineer. Locked means locked.
    Quote Originally Posted by Richie View Post
    2,262
    I'm a licensed dog walker and Stella drinker, I've never fitted a lock wire to anything and I have two IVA badges on my swimming trunks.
