Results 1 to 4 of 4
Thread: Propshaft Bolts
    Billericay, Essex, England.
    838
    Propshaft Bolts
    Hi all,
    I've recently changed to a digital rather than mechanical speedo.
    To pick up the signal I was going to use the propshaft bolts but wanted to swap to an allen / socket head rather than the current hex head.
    It is a Dax IRS rear with the 4 bolts on the prop. Think they are 3/8" UNF.
    Anyone done the same?
    What did you use?
    Assume they have to be high tensile?
    OR, is it easy enough picking up a signal off the hex headed bolts?
    Sean
    Aug 2002
    Through the Darien Gap
    998
    Sean,
    I turned up some circular spacers as a pick up and used longer bolts.
    Steve Brown
    May 2011
    Flimwell
    707
    I just positioned the sensor near the hex heads and it work perfectly.
    838
    Thanks both,
    I may try at first with the standard bolts then.
    Many thanks
    Sean
