Results 1 to 10 of 13
    Mar 2010
    1,246
    Fuel filler cap height
    Hi Guys,
    I am concerned about the height of the fuel filler cap that I purchased from finish line. Whilst I like it, my concern is the acceptable height above the body of the opening lever above the body for IVA.
    I have made sure that all edges are 3mm radiused (might not show in the images) but am aware that there is a restriction on height.......or am I missing something?
    Also I can remove the covering cap to reveal the locking cap below which would eliminate the height situation, or would this be seen as trying to avoid the issue and will fail on some other aspect?
    Any advice would be most appreciated.
    Paul.
    2,355
    I think 50mm is your height limit. But are you sure that will open all the way without hitting the body, I thought the alignment had to be different to that?
    The 50mm is measured off the wing, not the bottom of the recess.
    Dec 2013
    Newark, Notts
    70
    1,589
    I agree with Craig. Getting the opener in the correct position takes a bit of sorting using the various gasket sizes. I moved my filler to one side a little and tightened up the cap until it was a bit further round to the right to where your photo shows. If you do not get it in the correct position, you cannot open up the cap fully and it marks the body.
    Charlie
    Jan 2012
    Falmouth
    1,685
    You might get away with rotating the cap on you existing hole positions
    We tightened the cap on the base then marked and drilled to suit
    We also used one of the mounting screws to attach the earth to underneath too
    cheers
    AHP Crendon Chassis No 1
    9,170
    For information: I failed on this point at Gillingham using Brasscraft Aston roller rocker cap.
    Countless cars have passed with this, so its damned annoying. There are several ways in which 'the projection height' can be measured, as this is not laid down clearly in the regs. I fell foul of a less favourable interpretation.
    There are solutions out there, pm me if you need some assistance.
    Mar 2010
    1,246
    Thanks for the replies guys.
    Charlie; I had it orientated similar to yours but the latch side stuck out way too far for my liking. I then drilled and set a stop in the hinge side to prevent the lid hitting the body by a couple of mm.
    I wasn’t aware that I needed an earth on the filler cap, but if necessary is an easy addition.
    Kev, pm sent.
    Cheers guys.
    May 2011
    Flimwell
    866
    The filler cap must be earthed for IVA.
    Mar 2010
    1,246
    To follow on with my fuel cap dilemma........I had one made for IVA purposes. I couldn’t use the normal 3.5 inch caps out there because my filler is a 4 inch one from Finish Line in the States.
    A Local engineering company made this which is tethered and vented. The radius is 4.5mm on the top edge so hopefully should now pass without issue. Once I have gone through IVA, if there is anyone else thinking of using the FinishLine filler caps, I have a solution
    Feb 2016
    Scotland
    481
    Kevin W
    pm sent
    Jon W
    Jan 2014
    High Wycombe
    734
    Still no like button! Do you think they could/would make another one?
    Graham.
