Results 1 to 2 of 2
    Jan 2014
    Bingley, West Yorkshire
    34
    Brake pipe plumbing
    Hi All
    just hoping for a bit of advice
    I'm in the process of plumbing in my brake pipes........
    I am using a remote servo with front and rear outputs, when I split the outlets for left and right am I OK doing this at a convenient point or should I aim to keep the pipe lengths the same after the T piece?
    Thanks in advance
    Roger
    May 2011
    Flimwell
    830
    Shouldn’t matter where you split the pipes. It’s all about pressure which is equalised throughout.
    Colin
