Results 1 to 3 of 3
    Feb 2016
    Italy
    11
    Rear Wishbones and half arms modification GD427 JAG
    Dears,
    as I have a couple of spare arms and rear whishbones from an XJ6, I am going to reduce it to feet deeper rims and knock off hubs.
    the work will be done by a specialized shop but I need information on the lenght (reducton) of both the parts.
    Anybody already did this modification? Any indication on how much cut the arm and wishbones (7cm?).
    thank you guys for your time and attention
    s
    Aug 2014
    York
    438
    You might consider purchasing the wheels and tyres (plus hubs if needed) you desire first and then fit to your existing setup. You could then take exact measurements on each side to get the clearance in the arches you’d like. David has done this on here with his Dax and the result is accurate and looks fantastic. The clearances may be different on each side, certainly for a Dax, I have no experience of GDs. Best with it.
    Jul 2002
    notts, uk.
    64
    425
    I put 420 jag drive shafts and arms on my gd to get deeper rims but did not fit knock off hubs.
