    Aug 2008
    Norway
    Too much pinion slack?
    My Jaguar rear axle has much slack. Feels like it's too much for me, but are not sure .
    Typical very noticeable if I let off the throttle pedal after accelration.
    It make a "singing" sound in speeds around 60 miles/h, but other than that it's quiet and ok.
    No locker.
    I have read how to measure if the pinion teeths are enough engaged with the crown Wheel teeths, and am planning to do that. But how deep should the pinion teeths engage?
    May 2011
    Flimwell
    866
    You can read this:-
    http://www.thecarnut.com/Manuals/Sal...xleService.pdf
    But I suggest you get a professional to do it. Cost you about £400. russell_ram2 on this site is a master.
    5,000
    Postage from Norway for a diff might be a bit of a killer, though
    9,655
    To check if there is too much play or not you need to jack up the car and then fix one wheel and the input shaft so they cant move. Then turning the other wheel see how much movement there is on the edge of the brake disc, from memory more than either 1" or 3/4" (can't remember which) I think its 3/4", means there is too much play and it needs a rebuild.
    Aug 2008
    Norway
    Very useful information. Thanks!
