    Essex, UK
    3,909
    IVA brake test light
    Is a test switch required in the brake warning light circuit for IVA or is the handbrake switch considered sufficient?
    Simon
    2,260
    Hand brake is ok, assuming it lights the same bulb of course!!
    Apr 2014
    Stourport on Severn
    245
    As Craig says.
    However if you are using a Savage switch for the brake warning light it’s quite easy to also enable the switch function to test the bulb. There’s a diagram in my blog if it helps.
    May 2014
    750
    So if you use just one bulb, link it to a positive feed and make the negative feeds from the handbrake switch and brake fluid reservoir this passes IVA.
    The tester will just ask you to remove the brake fluid cap to confirm operation.
    Alan.
    AK Gen II on the road Jan '19
    Tremec T56 Terminator.
    3.27:1 Powr-lok LSD
    2,260
    I didn't realise until my first IVA test that the Sierra reservoir has a built in test switch on the cap.
    8,632
    The 'hand brake light' is not actually a hand-brake-on light - its a test for you fluid reservoir level! I think most modern cars use this principal, but most people don't realise this.
