Results 1 to 6 of 6
    Essex, UK
    3,866
    IVA brake test light
    Is a test switch required in the brake warning light circuit for IVA or is the handbrake switch considered sufficient?
    Simon
    WARNING: Translation of author's random thoughts may have resulted in the unintended introduction of grammatical errors, typos, technical inaccuracies, lies, propaganda, rhetoric, blasphemy, rambling, and/or exhibition of shocking levels of ignorance.
    44
    2,137
    Hand brake is ok, assuming it lights the same bulb of course!!
    Apr 2014
    Stourport on Severn
    237
    As Craig says.
    However if you are using a Savage switch for the brake warning light it’s quite easy to also enable the switch function to test the bulb. There’s a diagram in my blog if it helps.
    Steve
    May 2014
    666
    So if you use just one bulb, link it to a positive feed and make the negative feeds from the handbrake switch and brake fluid reservoir this passes IVA.
    The tester will just ask you to remove the brake fluid cap to confirm operation.
    Alan.
    AK Gen II delivery date Oct '15
    IVA pass Dec '18.
    On the road Jan '19
    Tremec T56 Terminator.
    44
    2,137
    I didn't realise until my first IVA test that the Sierra reservoir has a built in test switch on the cap.
    8,449
    The 'hand brake light' is not actually a hand-brake-on light - its a test for you fluid reservoir level! I think most modern cars use this principal, but most people don't realise this.
