Results 1 to 9 of 9
Thread: XJ40 Rear end
    Feb 2014
    bristol
    37
    204
    XJ40 Rear end
    I have an XJ40 rear end going spare if anyone is in the market for one. (Out board disc brakes)
    Complete with diff, drive shafts, hubs and brakes and associated bolts and hardware.
    No wishbones, as I believe most companies now make their own wishbones.
    As with all things Jaguar, it needs a good clean and refurb but going for a bargain as will be moving house in the near future.
    Looking for £100 - if anyone is interested, I can get the part number/ratio and stick up a few photos later on.
    Bristol based but happy to bring out to a motorway service station nearby for ease, unless the buyer wanted to see my car...
    Alex
    Jan 2005
    leatherhead,surrey
    974
    hi alex ,
    i'd like that please.
    are the lower wihbones same a earlier type with inboard discs - thinking of converting
    many thanks
    neil
    Southwest, Somerset, U.K.
    34
    3,163
    Alex
    If neil doesn't have it id be happy to do a deal and I am only down the road in taunton so easy to arrange logistics
    ANTHONY
    Absolute Horsepower Ltd
    Home of the CR427
    Feb 2014
    bristol
    37
    204
    PM'd Neil, but will give you a shout after we've spoken if its a no go.
    Alex
    Lanarks
    81
    Quote Originally Posted by neil still building it View Post
    neil
    Different bottom arms......think you need the 1993-1995 Jaguar axle parts.
    Same older style diff - Same lower wishbones as the XJ6 Xj12 XJS
    but with the newer style 1/2 shafts and hubs
    Same as my spare.
    Jan 2005
    leatherhead,surrey
    974
    good as i have the older lower arms already,
    and wanted the option of the later outboard disc setup as its easier to work on and has a better handbrake
    thanks for the conformation - and pic
    neil
    Lanarks
    81
    neil
    Not quite exactly the same.....
    The inner fulcrum is the same ( the long pin side) but the outer pin is a different size and your XJ6 bolt would need a couple of spacers itted to your arms.
    These late model 93-95 facelift Jag axles had the same looking bottom arms but the hole for the pin at the outside is slightly different diameter.
    Feb 2014
    bristol
    37
    204
    Now sold and collected
    Jan 2005
    leatherhead,surrey
    974
    many thanks to alex,
    it was a pleasure to meet you both - good luck with the car rebuild and house move
    neil
