Results 1 to 7 of 7
    May 2014
    Cranleigh Surrey
    11
    Jaguar Diff Mounting Bolt Torque
    Hi All,
    Does anyone know the correct torque value for the M16 diff top mount bolts? Can't seem to find this anywhere.
    Neil
    Sep 2004
    Bressingham
    1,341
    FT.
    Well, FT2
    Which is tighter than FT1
    Jan 2014
    High Wycombe
    653
    Haynes Manual 478 p.152.
    Crossmember to Final Drive bolts; 70 ft/Lb 95 Nm.
    Graham.
    May 2014
    Cranleigh Surrey
    11
    Quote Originally Posted by Gatwick Axe Man View Post
    Graham.
    Many thanks Graham
    2,305
    I assume that’s the Haynes Manual for the Jag?
    Do we think this settings are relevant where the Jag part meets the AK?
    Different vehicle weights, torque, materials etc?
    I guess it’s better than nothing?
    Just on open question you understand, not a criticism.
    Jan 2014
    High Wycombe
    653
    Yes, Haynes Jag XJS manual (not a Cobra 478, if one exists sorry my bad). Manuals have a number on the side to prevent confusion between marks and manufacture date ECT!
    Not sure where we go on the "switch" between donor and AK, valid point and not taken as criticism. I have been working on the premis that if it was good enough for the Jag it should be OK on an AK, thought process being the Jag was much heavier.
    Comments from all with a better skill set than mine more than welcome, but for now will still use the Haynes.
    Graham.
    Feb 2013
    265
    I would go with the Haynes/Jag figures on this. There's been some very questionable information on here fairly recently regarding AK diff mountings and fasteners (and theory on mechanical advantage and gear ratios) which I still can't quite believe I was reading.
