Results 1 to 3 of 3
    Jul 2015
    Cambridge UK
    34
    12
    LS3 Engine, T56, AK Gen 3 Cobra Kit - Loads of parts available
    Hi all
    It's with an extremely heavy heart that I've decided to sell up my AC Cobra build. I have a few project cars already and due to a change of career, I can't justify the spend on finishing this one (recently had our 1st baby so priorities have changed...)
    Parts for sale include -
    Fully Built LS3 Engine (Built and tuned this year by LS specialists LSX making 540BHP whilst staying IVA compliant).
    The engine being tuned -
    https://www.instagram.com/p/BhQ3OLJhiAd/?utm_source=ig_web_button_share_sheet
    Spec of build -
    LS3 pistons, hot washed and checked
    Mahle high performance piston rings
    Comp Cams Camshaft (not too aggressive but makes good gains and will pass IVA or MOT emissions)
    Comp Cams reduced travel hydraulic lifters (takes a lot of free play out the valve train)
    Comp Cams rocker trunnion upgrade (captive roller bearings)
    LS3 conrods
    ARP high performance conrod bolts
    Clevite big end bearings
    Clevite mains bearings
    MLS new headgaskets
    PAC uprated valve springs (to control the new Camshaft)
    New melling oil pump
    New water pump
    New front damper
    New F body oil pan
    One piece Manley pushrods
    All new gaskets and sensors
    New front and rear oil seals
    LS3 intake manifold
    90mm fly by wire throttle body
    This was turned on an engine dyno by Dave @Canems and made 530bhp whilst being IVA compliant -
    Parts I purchased from Canems include (I have invoice and receipt for £1785 in the VAT) -
    1 x ECU and harness suit AK Cobra LS3 @ £1200.00
    2 x Lambda sensor (LS installation) @ £68.00
    1 x GM air temp sensor @ £18.00
    1 x GM accelerator pedal sensor @ £134.00
    I also have a Tremec T56 6 Speed Gearbox from a Cadilac CTVS available. This comes with the shifter, OEM flywheel and clutch which will work with the LS3.
    As this is an ideal set up for a new Cobra project, I want to sell as one complete set.
    I'm currently looking for - £10000 for the lot which is a massive saving considering this is a drop in kit for a cobra and already tuned ready to go.
    I also have the AK Gen 3 427 kit (space frame) available -
    The kit includes -
    Basic Kit - Generation III
    3-Legged Roll Bars x 1
    Factory Fitted Wishbone Bushes
    Internal Boot Hinges
    S/S Fuel Tank Injection System
    Front Anti Roll Bar
    Coil Over Shocks & Springs
    Power Steering Rack Only
    XJ40 Handbrake Cable
    In addition to this, I purchased and reconditioned a donor Jag X300 (with V5) with all hubs, callipers, power lock diff etc.
    The front of the rolling chassis is complete, just needs the rear parts bolting up.
    I have a ton of other spares and parts including the BMW steering column, VW heater matrix basically everything needed to complete the rolling chassis.
    I'm looking for £8500 for the kit minus the engine/box/ecu or £1700 for everything purchased together.
    Any queries please give me a call. I have receipts for all parts.
    I have loads more photos but this post is limited to how many I can upload.
    Any queries drop me a line - 07944376546
    Jul 2015
    Cambridge UK
    34
    12
    Should of read £17000 FOR EVERYTING NOT £1700!
    Quote Originally Posted by Dfrancis View Post
    Hi all
    Spec of build -
    LS3 conrods
    MLS new headgaskets
    New water pump
    New front damper
    New F body oil pan
    LS3 intake manifold
    The kit includes -
    Front Anti Roll Bar
    Dfrancis,
    I am part way through building an ak 427 gen 2. Is the engine package still for sale?
    Rich
