Results 1 to 10 of 17
    Stevo pilgrim m3
    Hi I have a pilgrim cobra with a crap Granada rear axle I want to change to a jag . Can I have some suggestions on what type I should go for please many thanks Stevo
    Aug 2009
    547
    Quote Originally Posted by Steeevooo View Post
    What Mark Pilgrim Sumo do you have?
    What type of Granada axle do you have fitted?
    Jan 2008
    Basingstoke
    1,049
    Granada mk2 maybe? If it is it’s Good for 300bhp.
    Swapping the rear suspension for adjustable coil overs sorted out ride height and improved handling on mine. Might be easier than a full swap.
    8,168
    Why do you ssay its crap? Be useful to understand the problem properly before trying to suggest specific fixes.
    In general the main issue is to make sure you have an up-rated diff carrier, if yours is an early car.
    Also, if an early MkIII, it may not have all the triangulation of the later cars.
    Can you put up some pics of the rear axle from underneath, we can then comment properly.
    Lanarks
    64
    Jag with outboard brakes
    I have one here with a cross-member
    and adjustable coil-overs
    Get out your welder !
    Thanks all as you can tell I’m not a expert I bought the car second hand in bits . and a friend mechanic checked it over for me and diagnose the axle is out of line with prop Shaft and looks crabby so I thought of replacing to a jag axle in hope of getting a deeper rim as a plus thanks for your help . Hope I made sense 😂😂😂😂👍😢
    It was a 2.0 1982 Granada maybe I should keep it fix the problem thanks again 👍
    Cheshire
    50
    215
    Maybe a local club member could give it a once-over?
    How do you send pictures on here 😂
    Jan 2008
    Basingstoke
    1,049
    If it’s 82 then yes, it’s a mk2 Granada. You may find the 2.0 diff is too short (what engine??) - the 2.8 is a better option. There was a diesel diff but.... good luck in finding one!
    I think prop doesn’t/shouldn’t line up. As long as diff and engine are parallel (a parralelagram?) then it works...
    Getting a deeper dish is only possible if you flare the arches out (not something I’d fancy but it’s been done). You could chop out & fabricate you own rear chassis subframe....
    Some sumos are run with 225 at the rear, having just fit 245 - it makes a big visual difference.
