Results 11 to 20 of 21
    Oct 2006
    Toton, Nottinghamshire
    787
    Quote Originally Posted by v8muscle View Post
    Hi Russ,
    No immobiliser but I can do some checks on the ignition barrel. Is it possible something has gone bang inside there??
    It's possible that the ignition switch has failed. I've heard of a few going on other Cobras. Should be easy to test as "1dayiwill" has described. It might be worthwhile getting yourself a cheap multimeter.
    Russ.
    1984 DAX Cobra
    8,081
    Another suggestion for the multimeter. A cheap one is only a tenner or so, and can be invaluable.
    Oct 2009
    Tavistock, Devon
    69
    1,294
    Just bought another one for under £30. Lost my other one!Just make sure if you do get a cheap one that you can change the battery on it.
    Some of them you cannot, leave it on and you have one useless multimeter.
    Murray
    Oct 2006
    787
    Multimeter for 859 pennies.....https://www.screwfix.com/p/lap-mas83...600v/75337#_=p
    Includes the 9v battery too. It doesn't have test leads with crocodile clips on the ends, which can be handy, but a small sacrifice for the low price.
    Russ.
    1984 DAX Cobra
    Mar 2017
    Alton, Hampshire
    52
    Thank you very much 1dayiwill, I'll do exactly that.
    Many thanks!
    Jon LR
    Magnum with Ford 289ci & 4 speed Toploader
    Mar 2009
    liverpool
    280
    You can buy the crocodile clips that push onto the ends of the leads for £1 on eBay.
    Jan 2009
    Dronten, the Netherlands
    336
    If you find 12v on the battery terminals themselves, first thing is to make sure there is no corrosion between them and the clamps by cross measuring. So from - terminal to + clamp and vice versa. Then check mass connection on chassis and work your way up on positive side to fuse box and so on. Any relais maybe in feed circuit?
    BR, Theo
    Mar 2017
    Alton, Hampshire
    52
    Hi Theo,
    Thanks for the advice. There are a couple of relays, can they go pop? How do I test if they're good still?
    Jon LR
    Jan 2009
    336
    Not common, but they can. But first test if your fuses still have power supplied to them, do you have access to a multimeter? (It can be done with a 12v lamp with wires attached as said before)
    Reading, Berks, UK.
    1,436
    Another little suggestion to your armoury of testing equipment I have been using for some 45 odd years restoring old classics is a 12v Buzzer. Connect one end to earth and have the other end on a long long trailing lead, test each power supply you might think is dead/alive, good thing about a buzzer is you can have your head under the dash, legs over the back of the seat and not have to look at a meter or look for a lamp ( now my old eyes are getting bad it means glasses that always fall off )
    The other thing about some digital meters is that they may read 12v on a supply but if a load is applied the connection/switch/supply can break down thus giving the impression that there is a good 12v present. If a load is applied, ie a buzzer, lamp etc hopefully any load will show up a bad connection, lose cable fixing, crimp etc.
