Results 1 to 3 of 3
    May 2008
    North Yorkshire
    Shocks/coil -overs for Jag set up.
    Hi, any one got a set of shocks/coilovers for a Jag set up?
    Not looking for a decent set, just ones to use in the build phase to set dimensions etc.
    Stephen
    Surrey/Kent borders,uk.
    270
    Hi Stephen,
    I have a set for the Jag suspension as follows:-
    Two used AVO adjustable shocks complete with Suplex coil springs & two used Spax adjustable shock absorbers complete with Suplex coil springs.
    These coil over shocks have an extended length of 33 cms from eye mounting to eye mounting.
    The springs are rated at 375 lbs & have 9 coils each. These units are in good working order with no leaks etc.
    Would have cost over £500 new.
    £100 the set plus shipping. Let me know if you are interested on roger.portman@gmail.com
    Cheers, Roger
    Roger
    Magnum MkI
    Still looking for the Last Open Road ! ! !
    9,399
    Failing getting a set of shocks if it just to be able to reference things you can always use some steel rods drilled appropriately to hold the wheels at ride height. This is what I did when I set up the geometry of my suspension.
