Results 1 to 4 of 4
    Jan 2014
    High Wycombe
    514
    Can anyone double check some measurements for me please?
    Morning all,
    does anyone have a Jag' XJS rear end "laying around" that they can get to, to double check the measurements in the picture for me please? I think XJ6 parts are the same size so they would do. Yet again having a few "issues" with mine and just need to confirm measurements against similar parts.
    Thanks, Graham.
    Southwest, Somerset, U.K.
    34
    3,145
    I can have a measure in the morning but I can confirm XJS and XJ6 items are identical in this area
    What problems are you having
    ANTHONY
    Absolute Horsepower Ltd
    Home of the CR427
    Nov 2016
    Stevenage
    172
    Yes i have xjs rear on dax extensively rebuilt,what sort of issues?
    The issue i have was the ‘gap’ left over from the removal of the original jag ‘cage’ there are two thicknesses there on the inner pivot to deal with, just tightening up didnt fully solve as wouldnt go any tighter, and there is a little clearance in between the washers and seals. But bearings all nice and tight on shaft.
    The other is on the outer hubs pivot aparrantly there can be some shimming to be done in between the hub inner face and the inside of wishbone. ( not talking about the driveshaft endfloat)
    Jan 2014
    High Wycombe
    514
    Just a fitment issue I couldn't quite get my head around. All sorted now.
    Thanks all. Graham.
