Results 11 to 17 of 17
    Cambridge
    35
    1,189
    oooh yeah I love it when someone asks what to take to IVA because I get to post this
    good luck!
    Dave A
    May 2008
    North Yorkshire
    Large bottle of whisky.give it to the tester if you pass ,drink it if you dont!
    Dec 2009
    50
    287
    Hi ANDY
    my IVA is Friday in Norwich what’s the score with speedo I’ve got ETB GAUGES but haven’t been able to calibrate?
    Thanks Mark
    mark chambers
    Dax de Dion 350 Chevy
    9,521
    Try giving ETB a call , they were very helpful when I set-up my Speedo.You will of course need to tell them all the relevant information. Good luck
    2,305
    At the two IVA tests I’ve done, the tester has let me calibrate the Speedo on the rolling road.
    How is your sender set up? Prop shaft? Drive shaft? Gearbox?
    If it’s not the gearbox, send me your tyre size (and diff ratio if your using the prop shaft) and I can tell your pulses per mile to get you somewhere near.
    Dec 2009
    50
    287
    Many thanks for the replies I did speak to ETB this morning and as already quoted Very Helpful, I gave the rim size and diff ratio and changed the pulse pre set from 6000 to around 9400.
    The really helpful bit is that if you are near to fail for being over you just reduce that number so I feel much more confident in that part.
    A few other little jobs and all ready for Friday
    mark chambers
    Nov 2016
    Stevenage
    280
    Re seatbelts Can you use the special washers and spacers so that the fittings on the bolts rotate?
