    Jun 2005
    Norton Cross
    524
    Brake flexies routing
    Hi
    Just had a pre iva MOT and the tester picked up that the brake flexies were touching the wheel on full lock.
    How have others with Aks run the flexies to avoid this?
    Pete
    May 2014
    768
    You need to limit the rack, i think other have just used jubilee clips behind the steering boots.
    I didn't need to do this on mine.
    Alan.
    AK Gen II on the road Jan '19
    Tremec T56 Terminator.
    3.27:1 Powr-lok LSD
    Mar 2008
    Coventry
    2,328
    Quote Originally Posted by AKCobra View Post
    Alan.
    No you don't. You just need to adjust the hose and move it so it doesn't touch. Just undo the locking nut and twist it further up so it doesn't touch
    AK, on the road Oct 2012
    2,305
    If you’ve fitted 18’s you might need to limit the lock anyway to stop the wheel hitting the inner arch.
    If you do need to, jubilee clips won’t fit the AK rack, I tried !!
    9,521
    Quote Originally Posted by seph View Post
    This worked on mine OK although mine is a MK1.
