Results 1 to 10 of 15
Thread: Rear Fog light
    Nov 2016
    Stevenage
    224
    Rear Fog light
    Hi. Just wiring up rear fog, have read the regulations, when activating my rear fog switch, it only comes on on dipped AND main beam (ie not by itself and not with sidelights)
    whats the ‘controller’ i may need with reference to notes 3 and 4 in current IVA regs, ie when i turn my headlights all off, everything goes off right? When i switch headlights back on (forgetting that the fog light switch is presssed on still but actual fog is off) then the fog comes back on aswell. Though i do have a telltale warning light to warn me so, so do i need the ‘oops i forgot to turn of the fog switch’ controller as well?
    Sep 2004
    Bressingham
    1,313
    You don’t need the contraption.
    The manual simply gives definition of the feature being acceptable IF fitted.
    Nov 2016
    Stevenage
    224
    Yup nice one i thought so.
    8,409
    Your headlight switch probably has something like
    - Brown - feed
    - Red - side lights out
    - Blue - Dip /Main out.
    You might then have another switch to flip between main and drip.
    You just need to intercept the Dip/Main out for the fog light feed. That should provide the right logic for the lights, as stated in the OP.
    Nov 2016
    Stevenage
    224
    - Brown - feed
    Yup was all built in the IVA premier wiring loom, it was just a trade supplier on this part mentioning the fog light latching switch that would keep the fog light on if you forgot to turn it off, so if you turned the lighting switch off then came back next day no fog, turned the light switch on and fogs come on unecessarily and you wouldnt know. Except i have a fig warning light so should suffice
    1,155
    My fog light is on a switch, no lights on, it won't switch on. Which is correct BUT it will switch on when I turn on side lights and dipped headlights and main beam, I cannot see any reference to side lights in the IVA manual, so will this pass IVA?
    Thanks Lee
    3,741
    Thanks Lee
    Nope. Ask Kev how he knows...
    Lanarks
    91
    3,741
    Yup, that's what you want - rear fog with main & dip, but not sidelights. Kev read the IVA manual incorrectly the first time through, as did I when I was trying to argue that his tester was wrong .. until I re-read the IVA manual for the third time and noticed that front fogs can be on with sidelights, but rear fogs must only be on with dip & high beam. Whoopsie.
    May 2014
    663
    Quote Originally Posted by dinosoar View Post
    Sorry this is incorrect, yes you do mine failed IVA on this just before Christmas.
    It is imperative that you can ONLY put the fog lamp on with DIP/MAIN beam and that when the lights are turned off then back on the fog light does NOT illuminate again.
    I find the manual very grey on this, as i set it to work with a module on both side lights and dip/main and failed! I had to remove the feed from the side lights to overcome this.
    Alan.
    IVA pass Dec '18.
    On the road Jan '19
    Tremec T56 Terminator.
