Results 1 to 2 of 2
    Christchurch, Dorset
    186
    Question Steering Rack Inner Rods
    Hi
    I have a mk3 Dax that I built in 2000 with the Dax supplied steering rack. I have play in the inner rod end, so tonight I removed the rack and removed the inner rod to find the plastic bearing cup had collapsed. Does anyone know who modified these racks? I am trying to work out if I can get hold of a replacement inner rod or a replacement bearing cup to go behind the existing one.
    Neil
    I should be called "Nearly There" But I was drunk when I joined this club!
    May 2009
    Blaenau Ffestiniog, N Wales
    135
    Did you get sorted ? Just got a brand new rack from Dax so it may be the same type...think it was built by Quakes but would have to check the shed.
    cheers
