Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 33
  1. #21
    1,385
    I have seen reports of some people converting over to poly superflex or powerflex purple bushes. Reports of harder ride and squeaking so I have stayed away from them. It will be interesting to see if any one has good reports.
    https://www.powerflex.co.uk/products...29-2816/1.html
  2. #22
    2,448
    I'm not a fan of poly bushes for just those reasons. Rubber bushes may deflect slightly but they are frictionless which the poly bushes are not. However, for the shock mounts which see very little angular movement I think they would be OK.
  3. #23
    2,448
    Regarding the shock bushes, I got a reply from Spax:
    "Sorry to say I have no idea which bush that is as the damper precedes 1999 when our company changed hands."
    But they did supply a useful looking link:
    https://spax-suspension.com/Spax%20Bush%20Details.htm
  4. #24
    Mar 2008
    warks
    85
    I swapped to AVO shocks a few years ago and have found them an improvement over the spax - easier to adjust and came with harder polyurethane bushes. Interesting that you felt the original spax were too short..I replaced them with ones the same size but followed cheng's advice about spring rates. I too am rebuilding after 25 years - the rear end and other jobs that appear. I have r had the diff rebuilt and changed the ratio, replaced the rear discs and calipers and painted the chassis with POR15 where the coating is flaking off. I bought a Corsa steering rack to fit power steering, so I could fit bigger tyres to the front , but haven't fitted it yet. People seem to rate it so hopefully it will be a good upgrade. I have left all the bushes as original jaguar, and have been amazed at how easily the suspension has stripped down and re built - compared to the nightmare I had stripping the original axle when I built (everything had seized). Another vote for copper grease!
    Went to the Kit Car show yesterday - seems to be a shadow of its former self , less stands and no 'new ' kits, and a lot less owners cars. Sad.
  5. #25
    2,448
    Fitting a new roller cam, hoping that it will better match the carbs I'm running (Webers)
    And just for fun new timing gear too. Plan is to convert to distributorless ignition hence the trigger wheel on the crank
  6. #26
    2,448
    Fancy billet timing cover is on (you can see the crank and cam position sensors), with the help of the wonderful David Vizard book at all times
    Is it just me or has the forum stopped showing thumbnails?
  7. #27
    Newcastle upon Tyne
    1,916
    . . . .Is it just me or has the forum stopped showing thumbnails?
    Myles,
    No, it is not just you. I have heard nothing officially, despite requests, but I am sure that the way in which pictures are hosted has changed - probably with recent upgrades to the software.
    My understanding is that the site no longer hosts the image but relies on it being held somewhere on the web by one of the many image hosting sites. the way the image is linked to the CRC, and the format in which it is uploaded & held on the hosting site, will determine how it is shown when linked to the forum post.
    This is all just my opinion and I would welcome any other thoughts on the matter.
    Regards,
    Ian
    PS Sorry, meant to say I am enjoying your upgrade - thumbnails or not!
  8. #28
    2,448
    Thanks Ian. It's a retrograde step, making the forum less readable, and with disk space as cheap as it is now, being 'precious' about storing images seems very old fashioned. It's the only forum I post on that has done this.
  9. #29
    4,334
    Most forums I post on have no functionality for hosting images on the forum itself, your only option is to use an external service and link them in (like https://imgbb.com).. disk space might be cheap, but bandwidth isn't..
  10. #30
    2,448
    Anyone who has built a Ram cast their minds back to pinion angle...
    I never even checked it when I built my car and it has never been an issue. Now while I have the thing in bits I notice that the pinion flange is nowhere near parallel with the gearbox flange - over 5ยบ out. I can't see how you would fix it, the pinion angle is fixed by the diff being bolted to the chassis and the gearbox mounting would have to drop down way too much to make the pinions parallel.
    Anyone else come across this?
