Results 11 to 13 of 13
    Jan 2014
    High Wycombe
    624
    Feb 2003
    Devon
    7,767
    The wiper boxes just transfer the drive from the wiper motor so if you want the wipers to sweep less or more you can change the wiper motor gearing.
    You then adjust the wiper arms in a few different ways. Rotate on the wiper box and re-clamp. Bend the wiper arm end. Shorten or lengthen the wiper arm.
    Various kit manufacturers might recommend different gears for their particular car but they shouldn't really be much different because the screens are the same size.
    May 2011
    Flimwell
    784
    For IVA :- If you have 2 wiper blades then you need a 130 degree sweep. If you have 3 blades like AK you can get away with 110 degrees.
    In order to cover sufficient % of the screen.
    Colin
