Results 1 to 10 of 19
    Apr 2006
    Glasgow
    229
    Electric hand brake
    Hi , has any one fitted an electric handbrake ? Was thinking of using a vauxhall electric motor pulling the cable with a power switch on the dash. Have i over simplified the upgrade ? Thanks
    james
    GD 427 euro LS1 Magnum T56 (sweet)
    Oct 2009
    Tavistock, Devon
    69
    1,307
    See here James, Craig Perry has done one I believe.
    http://www.cobraclub.com/forum/showt...ght=hand+brake
    Murray
    Apr 2006
    Glasgow
    229
    Hi thanks for link.
    james
    Jan 2016
    Middlesbrough
    Hi, I fitted an electronic calliper solution from Hi-Spec. It's quite neat as it's a single solution acting on the disk i.e. no need for spot callipers, separate handbrake mechanisms, cables etc.
    I had to have the original Jag disks replaced with larger, bespoke disks, so it was quite an expensive solution. But, hopefully simpler to maintain.
    I tried attaching some pics, but not having much luck
    Jan 2016
    Middlesbrough
    Hi
    Managed to attach the images (the original file size was too large).
    Hopefully, this gives a better idea of the overall solution.
    Russell
    Apr 2006
    Glasgow
    229
    Thanks Russell differently worth some thought, build looks good.
    james
    I've fitted one to a GD. Used a linear actuator to pull the cables, bought the actuator from a robotics shop. You can't just connect it up to a switch as you need to switch it off at a preset torque otherwise the actuator motor will stall and burn out. Also for IVA you have to be able to apply the handbrake with ignition off but not be able to disengage the handbrake. It works really well though.
    Ashley
    2,118
    Quote Originally Posted by AshleyD View Post
    What was your solution to that problem?
    I use an Arduino to measure the current going to the motor and to stop the motor at a certain value. If you are into tinkering a bit with electronics then this is a good solution at reasonable cost. I'll try post a couple of photos of the installation later.
    2,118
    You lost me at Arduino
