Thread: Oil Dilema
    Feb 2006
    Somerset
    1,076
    Oil Dilema
    Hi
    Doing an oil change on the Cobra before the summer season. I have always used Lucas Racing Only Semi Synthetic SAE 20w-50. I have struggled to get this but found some on Amazon. Anyway to cut a long story short they have sent me Lucas Racing Engine oil SAE 20W-50 New ZINC Tech which is neither semi or fully synthetic. My question is can I use this in my Ford 347 to replace the existing oil or do I have to go through the nausea of sending it back and finding a substitute? My old oil in the picture is on the right. The oil I have been sent is on the left.
    GD427 Mk4. Chassis No J0258
    Ford 347ci Stroker - AFR 185 heads - Holley 670 - KB Pistons - Lunati "Voodoo" 272/280 Cam - 451 bhp/441 lbft.
    2,960
    the consensus has always been 20w50 Mineral oil on these oldschool V8's. I've always used Valvoline VR1 20w50 until engine rebuild when builder changed it to Lucas 10w/40 (http://www.lucasoil.co.uk/products/h...w-40-motor-oil)
    I gather it depends a lot on rocker type you have installed i.e. flat tappet or hyd rollers etc - someone in the know will be along shortly to answer
    Forgot to say it was always the Zinc level that determined the oil make to use, VR1/Millers/ etc have high(ish) Zinc contents that newer semi and fully synthetic oils
    http://www.lucasoil.co.uk/images/doc...orcycleOil.pdf
    rgds
    Gary
    Feb 2006
    Somerset
    1,076
    The Cob has roller rockers and a stroker kit.
    2,960
    Did you build yourself Martin or built for you - worth asking the build if the latter.
    Mine is the same, albeit a chevy unit, hydraulic rollers and cam with stroker kit - always used 20w50 mineral prior to engine rebuild (new cam, lifters, springs, etc, etc) and builder changed to 10w40 mineral - bit of a bugger cos it's like rocking horse poo to get, lol.
    rgds
    Gary
    Feb 2006
    Somerset
    1,076
    rgds
    Gary
    Built it myself but three or four years ago. Took it to Kenny Coleman engineering for a Dyno and he put the Lucas racing oil in. Used it since ( two oil changes) but am open to options if I can use something that is easier to get hold of.
    2,960
    if it was Kenny who put it in, then stick with it Kennys choice
