Results 1 to 8 of 8
    Jun 2016
    Nantwich Cheshire
    286
    AK Boot Gas Ram Brkts
    I'm in the process of fitting the AK boot gas rams.
    The brackets supplied are are about 6 inches long.
    i.e the bit that is meant to be bonded to the underside of the boot.
    When you offer the brackets up only about 3 inches contacts the body due to it's contour.
    Am i missing something? Do they need to be bent to match the body or can I just cut them to length.
    Mike.
    Apr 2014
    Stourport on Severn
    242
    Here’s how mine went
    Lincolnshire
    326
    Is that a spider crack appearing towards the bottom right of your photo?
    Crendon 427 Chassis no. 10 - 351 Cleveland. Tot Rod mini me.
    Aug 2002
    Through the Darien Gap
    1,027
    Quote Originally Posted by Yellowbelly View Post
    You've got damn good eyesight if you can see it's crack!
    Steve Brown
    Apr 2014
    Stourport on Severn
    242
    Definitely a real spider!
    Jun 2016
    Nantwich Cheshire
    286
    Thanks for the pic Steve.
    Most helpful..
    2,209
    What did you use to bond those Steve?
    The only thing I could get to stick was P40
    Apr 2014
    Stourport on Severn
    242
    Hi Craig, I used some body filler from Toolstation, Think it was called Big Boy !. Seems to have done the trick and I also used it for sticking some cable ties under the wings. All still in place.
