    Jun 2016
    Nantwich Cheshire
    52
    273
    AK Polo Heater hoses
    I am about to do the final fit of my body.
    I was wondering do I need to fit the heater feed pipe to the polo heater before the body goes on?
    It looks like it would be tricky to get at once the body is on.
    The reason for asking is I’ve ordered the samco hoses but it doesn’t look like they will arrive before my lifting party does…
    Mike.
    Aug 2016
    WELLINGBOROUGH
    91
    Although a bit tricky the hoses will go on after the body is on.
    If you have had the engine compartment st.st. lined now is a good time to remove the protective film. It's **"£$^%£ awkward afterwards!
    Have a good party.
    sceptic
    Jul 2013
    Bristol
    307
    Quote Originally Posted by scepticwoody View Post
    Have a good party.
    sceptic
    It's **"£$^%£ awkward without the body on!
    AK427 - Modified LS3 - TKO600
    Build started September 2014
    OTR March 2017
    legendarydude.com
    2,134
    Depending on your engine choice..... You have fitted the air pipe to the cabin off the heater haven’t you??
    Sep 2015
    Berkshire
    29
    Quote Originally Posted by Mwalker56 View Post
    Recent experience says I'll second that.............!!
    The covering sticks to the SS like the proverbial **** to a blanket and finding a starting point from which to pull it from isn't easy (but that may have been the wrong glasses and the lack of finger nails..........!!
    I took a different approach with the heater and fitted a couple of 'fly' hoses to the heater inlet and outlet. They were fiddly to connect to the main heater hoses with the body on because they were so close to the chassis cross member (Gen 3)
    AK Gen 3 with LS3. Build start January 2019
    www.flickr.com/photos/marlinbuild/
    Jun 2016
    Nantwich Cheshire
    52
    273
    Cheers Chaps,
    My heater hose has arrived so I'll stick it on before dropping the body on.
    I've removed the SS covering. Was actually pretty easy but it was a nice hot day. I'm sure this helped.
    Yes I am drawing air from the cabin....
    My only other question is should I put drain holes in the floor pan under the tub.
    I'm using the neoprene type seal and I recon water will get in there...
