Results 1 to 2 of 2
Thread: Radiator
    Blackpool
    309
    Radiator
    Hi. Has anyone tryed using one of these?
    https://www.ebay.co.uk/itm/3-ROW-ALU...75.c100623.m-1
    It's a bit norrower that the SD1 3 core rad but the inlet and outlet still look to be in the same area. I think some of the pipework will need changing due to the width being smaller.
    Your thought would be very much appriciated.
    Anthony
    1,366
    Hi Anthony,
    The one that you show is very narrow compared to what you can fit so you will be loosing out on core size by some 30% .
    Core Size: 408x416x56mm = 1697 cm2 . Compared to a Nissan s14 200sx core size 635 mm×360 mm×52 mm 3 rows =2286 cm2 which you should be able to fit.
    You could also look at NISSAN-SILVIA-240SX the height including the filler cap is a bit larger 485mm but you might be able to fit it in . The outlets are correct and the core volume area is 2304cm2 and 52mm core.
    Core Size: 360x642x52 [mm]
    Overall Size: 485x670x98 [mm]
    https://www.ebay.co.uk/itm/3-ROW-ALU...MAAOSwV45bsHHM
