    Jun 2005
    Huddersfield
    280
    ‘Clear-out’ parts for sale - mostly Rover V8
    Hi, I’ve been having a clear out, and can despatch via Hermes at cost.
    Lumenition Optronic PMA50 ignition module only, new and unused, but no box, NOS (New Old Stock): £50.
    Universal choke cable, 1.9m long, twist to lock, unused, NOS £4.
    Rover SD1 V8 9.5” 241mm clutch friction plate - genuine Borg & Beck 52509, NOS: £40.
    Rover V8 clutch release bearing and carrier, used but smooth rolling: £5.
    Rover SD1 V8 front timing cover ERC0036, Rare - gives low level water pump. Bare, with hole for distributor: £50.
    Range Rover V8 front timing cover HRC1321, More common - gives higher level water pump. Bare with hole for distributor: £50.
    Rover SD1 V8 alternator mounting bracket ERC0303. Normally underslung, easily modified to overhead: £10.
    Rover SD1 V8 41673A 35DE8 distributor with Opus electronics, a bit scruffy but has the important skew gear with oil pump drive and rotor arm. Ideal for converting to Lumenition. £30
    Rover SD1 V8 water pump pulley for v-drive belt. Black painted: £5.
    Please let me know if you’d like photos of anything.
    Regards, Martin.
    Jun 2005
    Huddersfield
    280
    Hi, a quick update:
    Rover SD1 V8 9.5” 241mm clutch friction plate - genuine Borg & Beck 52509, NOS: £35.
    Regards, Martin.
    Jun 2005
    Huddersfield
    280
    Another quick update:-
    Rover SD1 V8 9.5” 241mm clutch friction plate - genuine Borg & Beck 52509, New Old Stock: now £25
    Range Rover V8 front timing cover HRC1321, Bare with hole for distributor: £50.
    Rover SD1 V8 41673A 35DE8 distributor with Opus electronics, bit scruffy but has the important skew gear with oil pump drive and rotor arm. Ideal for converting to Lumenition. £30
    Regards, Martin
    Jun 2005
    Huddersfield
    280
    Another quick update - nearly all gone:-
    5mm X 9mm 2.4m long hollow PVC wing piping/beading - ideal for fitting around stone guards. (New Old Stock) 5mm hollow tube, with 9mm flange attached. £6.50
    Rover SD1 V8 41673A 35DE8 distributor with Opus electronics, bit scruffy but has the important skew gear with oil pump drive and rotor arm. Ideal for converting to Lumenition. £30. NOW £25
    Regards, Martin
    Jun 2005
    Huddersfield
    280
    Just the dizzy left - make me an offer?
    Rover SD1 V8 41673A 35DE8 distributor with Opus electronics, bit scruffy but has the important skew gear with oil pump drive and rotor arm. Ideal for converting to Lumenition. £30. NOW £25ono
    Tel 07972 282536.
    Jun 2005
    Huddersfield
    280
    all parts now SOLD.
    Thanks for your interest.
