Results 1 to 7 of 7
Thread: Fuel anomaly?
    May 2019
    Droitwich Spa
    3
    Fuel anomaly?
    Does anyone know if the fuel pressure regulator on a Chevy 6.3 is adjustable or not?
    I’ve got an issue where I think the car is flooding itself as under load at low revs it will splutter and cough and try and cut out. The gauge is reading about 12 psi and I’m not sure if this is too high and possibly the cause.
    I'm new to cobra ownership and would really appreciate any help if anyone has had something similar?
    9,439
    If you are running a Carburettor ? then that is way too much pressure. You should be getting more like 4 PSI.
    44
    2,118
    Is it an LS with engine management?
    May 2019
    Droitwich Spa
    3
    No it’s not an LS and I thought it was too high! Do you know if it’s adjustable? It doesn’t look like it but it must have been set in the first instance!
    Thanks for the quick reply
    May 2019
    Droitwich Spa
    3
    If I can figure out how to, I’ll post a picture of it!
    cheshire
    1,131
    A picture of your set up would help, if it's a holley carb it 7 psi max. Picture first then the solutions will.come flooding in.............sorry I really didn't mean that pun!!
    721
    Adjust to 5-6 psi . You might or should have an in-line pressure regular similar to this one below.Filters the fuel and manages the pressure. 12 psi is way to height and could damage the seals.
    https://www.demon-tweeks.com/malpass...E&gclsrc=aw.ds
    There is a locking nut and adjustment screw on top.
