Results 11 to 13 of 13
Thread: Sumo Brakes.
    Nov 2013
    My Garage
    987
    Which rear discs did you use please Ken & where did you source them ? Cheers !
    They were on my heap when I bought it. I did buy replacemt calipers for them which were Granada so assumed the discs must have been granada
    Jul 2004
    Egham, Surrey
    362
    Quote Originally Posted by Ian C View Post
    I upgraded the front rotors to Brembo 260mm grooved & vented with EBC Green stuff pads and fitted new standard 253mm solid rotors on the rear with Mintex pads...
    Which wheels do you have and were there any issues with clearances with the new discs/calipers or did these just swap straight on? I'm contemplating a similar swap.
    Finished the car, but not the website!...
    http://www.sumobuild.co.uk
    Newcastle upon Tyne
    1,915
    The Brembo discs are the same size (260mm) as the standard disc so no clearance issue. I am running team Dynamics Pro Race 1.2 17" wheels and plan to fit the Hi Spec 300mm rotors which require a minimum 16" wheel.
