Results 1 to 8 of 8
    Jun 2012
    Essex
    65
    195
    Starter Motor ‘Flat-Spot’
    Hi guys I have a 350 Chevy/Tremec T5 fitted with a Mini Hi-torque starter motor – the whole package having covered only 1,800 miles. Just recently when I try to start the car (cold or hot) the starter solenoid (?) clicks as if the battery was flat or low charge, however when I rock the car backwards and forwards in gear, I am then able to start the car….
    Any thoughts as to what the issue might be?
    Thanks Craig
    31
    Hi Craig,
    I would check the out of mesh clearance ,most starter motors are about an eighth of an inch.
    Also check the obvious things like earth cables etc,
    regards ,
    Jun 2012
    Essex
    65
    195
    Sorry Chris, but could you elaborate a little on what you mean by 'mesh clearance'?
    9,495
    Quote Originally Posted by Doc Craig View Post
    I think what he means is that when fitting a starter motor on a Chevy, you are supposed to shim the motor to get the correct engagement of the starter and flywheel teeth. I'm sure someone will soon correct me if I have got that wrong.
    31
    The mech clearance is between starter motor teeth & flywheel and may need a shim to adjust it if to tight as mentioned by Tinka.
    The clearance is fairly critical for correct engagement,
    Hope this helps,
    Jun 2016
    Nantwich Cheshire
    281
    A standard paperclip is a good gauge.
    If you unfold a paperclip you should be able prod it between your starter teeth and your flywheel teeth.
    If you can't your clearance is too tight. The Real steel website has some good info on the subject.
    Jun 2012
    Essex
    65
    195
    Thanks guys. I'll get to it
    818
    There are a few different videos on youtube . This one covers it well. The paper clip is the method most discuss for the mesh gap but this one also covers the depth .
    https://www.youtube.com/watch?v=IVHXmWMKzq4
