Results 1 to 2 of 2
Thread: Loom issue
    Dec 2015
    Walsall
    150
    Loom issue
    Checking all the electrics today, connected the battery turned isolater key on and found issue with lighting cable. The red and yellow cable for side lights and main lights this cable was live even without turning ignition key on. Disconnected the cables to ignition switch this cable was still ready 12 volts. any ideas .
    Richard
    Sep 2015
    Berkshire
    35
    Richard,
    With the light switch in the on position the side light feed will be live with ignition off. But the main light feed should only be live with the ignition on and controlled by a relay. If your main light relay has failed in the closed position or the relay is wired incorrectly, you could be feeding a permanent live to your main lights..................................
    Just a thought
    Nigel
    AK Gen 3 with LS3. Build start January 2019
    www.flickr.com/photos/marlinbuild/
