Results 1 to 10 of 12
    Marlow
    69
    1,858
    Steering wheel puller
    Hi guys, have any of you had to resort to a puller to remove a stuck moto-lita steering wheel? It's just not centered..
    Local garage and I have tried but the bugger just won't move. All their pullers don't fit!!!
    Seeing if I can buy something before either making one or undoing the ujs and realigning.
    Cheers Clive
    On On
    4,431
    If you undo the UJs, don't forget to keep them all 'in time' with each other! Which means you'd likely have to split it at the rack..
    Marlow
    69
    1,858
    Good point thanks!!
    Feb 2013
    331
    WD40 and a bit of wiggling.
    Marlow
    69
    1,858
    Wd40 and loads of wriggling, two people pulling, one pulling and one hitting center shaft, prayer, swearing,you name it!!! Needs a puller.
    Aug 2014
    Leicester
    216
    Yes. Used a standard 150mm puller but needed to add an extension to the centre screw to enable it to reach the splined shaft. Fiddly to setup but then came of easily when correctly aligned.
    Feb 2013
    331
    When you eventually get it off, I suggest you don't refit it dry - apply some copper grease to the tapered section. That is where it's getting stuck.
    Nov 2006
    Shropshire/Wales Border
    50
    6,057
    you probably know this already Clive, but leave the nut on a few turns.... saves getting spoke marks on your face when it finally pops free!
    Lloyd B
    Marlow
    69
    1,858
    Two very good points, copper grease and most importantly leave the nut on!!!! A couple of comments on other forums discuss dentists bills and concussion.
    Cheers Clive
    Marlow
    69
    1,858
    Was the 150 pulled from screw fix?
    Cheers Clive
