Results 1 to 10 of 17
    Peak District
    346
    speedometer sensor
    I'm trying to get a speedometer sensor from speedycables working with my DAX. I've mount it adjacent to the propshaft UJ in front of the Differential but for some reason the speedo isn't registering any MPH. Does anyone know how close / far the sensor needs to be from the propshaft before it picks up a signal?
    Thanks in advance,
    Mark
    2,343
    It needs to see pulses from magnetic bolts (or magnets bonded on), what is your sensor looking for?
    Needs to be within about 4mm I think
    Peak District
    346
    Thanks. I've missed something pretty fundamental! I haven't got any magnets on it. I'll bond some on and see if it works.
    Mark
    2,343
    I made a bracket on my AK to look at the prop shaft bolts. Again, you need to make sure they’re magnetic.
    You then calculate the pulses per mile, taking into account wheel diameter and diff ratio.
    Or just us a satnav/phone app to match your speedo to
    May 2011
    Flimwell
    866
    I’m pretty sure you don’t need magnets if it’s an inductive sensor. The bolt heads must be ferrous (a magnet will stick to them) and stainless steel is no good.
    With a gap of 1 or 2 mm you should be getting a good pulse which will light up the led on the sensor.
    If you aren’t getting the led to flash then you need to check the wiring.
    Apr 2012
    swansea,south wales
    187
    if you have a sensor with 3 wires it is a hall effect switch which requires magnets to trigger it ,if its a two wire sensor its probably a magnetic reluctance switch which will trigger from steel bolt heads. a 3 wire sensor connects + and - and output to speedo ,however a 2 wire sensor has one wire connected to ground and the other to the speedo hope this helps,best of luck mike
    mike
    pilgrim sumo mk3 3.5l rv8 sold
    ak gen 1 ford 302ci otr
    Jul 2007
    peterborough
    240
    Quote Originally Posted by petrolhead27 View Post
    The 3 wire sensors do NOT require magnets, they pick up from the nuts/ bolt heads, you need to be no more than 2mm from the heads. If it's a speedy cables sensor it will have a led light where the wires go into the sensor, this should light up when you pass a bolt head.
    Brown wire is +12 volt
    Black wire is signal to speedo
    Blue wire is earth.
    If the led doesn't light up you probably have no live feed.
    Jon
    AK Sportscars
    Dec 2013
    Newark, Notts
    70
    1,583
    Make sure you use ferrous bolts. You do not need magnets. I have found that the sensor needs to be as close to the nuts as possible or else it does not work. If you are placing the sensor against bolt heads then make sure you check each one as you can easily damage the sensor if you get the slightest touch on the nut head.
    Blackpool
    309
    Hi Mark
    What speedo and gearbox are you using?
    Anthony
    May 2008
    North Yorkshire
    Hi, is this method IVA/SVA acceptable? I know they wont accept GPS ones
    stephen
