So thinking ahead to next years Le Mans classic. In 2016 I had real problems with a very stiff clutch and bite point nearly on the floor. At the end of that trip slave cylinder was replaced and 2018 went great until drive home from Dover when similar problems started to occur. To be honest haven’t changed anything since then and generally it’s worked okay but at the end of longer runs clutch starts to get stiff at bottom of pedal travel. My next course of action was going to be a clutch fluid change and was starting to think about using a higher temp fluid. Any other suggestions would be welcome.
