Results 1 to 4 of 4
    Dec 2009
    Barton Mills,Bury st Edmunds,Suffolk
    235
    Question Ford Sierra headlight low high beam switch?
    Hi all just a quick question the left hand column switch from the 1987 Sierra the round hazard warning light button type, with the ignition on should you be able to flash the headlights or do you need the headlights to be switched on? IVA looming?
    Mark
    mark chambers
    Dax de Dion 350 Chevy
    44
    2,127
    Surely they should flash independently of the headlights??
    Quick test, does your daily driver do it?
    May 2005
    Sheffield
    1,011
    A Sierra is my daily driver..... the main beam flash is only with the ignition on, and doesn't matter if the headlights are on or off.
    Nuf Said
    Jul 2002
    Curridge, Berkshire
    862
    If these stalks are anything like the mk1 stalks then there is a switched live wire into one end of the flash circuit when when the stalk is pulled back provides the 12v to a relay to drive the main beam.
