Results 1 to 10 of 10
    Dec 2013
    Bletchley, Milton Keynes
    210
    Tremec gearbox crossmember
    Hi Guys
    I have a Gen 1 AK with a Tremec 5 speed gearbox with a piece of angle iron as a cross member I cannot believe this is the normal way to keep the gear box in and was wondering if any of you guys had a different approach as it looks so cowboyish ??????? or is there a pre made one that fits.
    Rich
    Rich
    AK427-FORD 302- Angus Racing 1.6 roller rockers, 282 Solid lifter cam, KB Pistons, Eagle forged H Beam rods, Holley 600cfm, Weiand Stealth Intake Manifold, Tremec TKO 500
    Jun 2014
    Redditch
    111
    Hi Rich. I used a bracket that AK manufactured and supplied as part of the kit. Secured to the chassis with 4x M10 bolts
    Jan 2017
    Mansfield, Notts
    91
    What's wrong with home made angle iron cross members
    Mar 2012
    Nr Northallerton. N.Yorks
    174
    I used the ak supplied piece and uprated it by welding additional flaps to it to lengthen it slightly to give more support and added a couple more bolts ...quick and easy to do whilst giving peace of mind
    Dec 2013
    210
    no idea if my photo loaded but mine just looks naff to me.
    Rich
    Jan 2017
    Mansfield, Notts
    91
    Quote Originally Posted by jaguar420g View Post
    IMG_1002.JPGached file to you
    I can't see any photo or attachment ?
    Dec 2013
    210
    I dont understand why not as I can see it ???? strange ! but I won,t bother changing the angle iron then as it doesn't seem that important to people
    Rich
    Rich
    Jan 2017
    Mansfield, Notts
    91
    Rich
    As you said it might not be the best looking thing on the car. As long it's doing what it should and no one else can see it is it worth changing ?
    Pete
    Legendary 427 one off Cobra rep
    SBF 302 Efi, T56, Ford Running gear and LSD.
    8,941
    What Pete said.
    You could pop plastic thread protector caps on the nuts, to make it easier to remove should the day come.
    Else, I'd leave it.
    Dec 2013
    210
    Thanks Guys
    Point taken I sometimes start to get a bit anal when I,m going over the car to see what to do next.
    I shall leave be.
    Rich
    Rich
