Results 1 to 8 of 8
    Jun 2005
    Huddersfield
    280
    Starter motor for small block Ford V8 with
    Visteon 11000 12 volt starter motor for small block Ford V8 engines.
    This is a ‘high-torque’ small bodied type of starter motor with a ‘short-nose’ suitable for engines with the flywheel having the ring gear fitted nearest to the block - usually 164 tooth flywheels. This motor is used, but in very good condition, having done less than 9000 road miles since new.
    Will be shipped 2-3 day tracked service with insurance to the purchase price. (4Kg. £8.50)
    Jun 2005
    Huddersfield
    280
    This is a ‘high-torque’ small bodied type of starter motor with a ‘short-nose’ suitable for engines with the flywheel having the ring gear fitted nearest to the block - usually 164 tooth flywheels. This motor is used, but in very good condition, having done less than 9000 road miles since new. £45.
    Jun 2005
    Huddersfield
    280
    Damn photos won’t display!
    Nov 2016
    Stevenage
    291
    Hi is it def 164t ( the larger fly) as i think its a different starter fir the 157t ( or whatever the smaller one is). Thx
    1,170
    Ford starter motors for 164 and 157 tooth size depends on a lot of variables. I have Ford Cleveland and T5 box yet fit what is classed as an auto starter motor. The depth is the main measurement of the gear face. This document explains
    https://static.speedwaymotors.com/pdf/91067433.pdf
    Jun 2005
    Huddersfield
    280
    Hi, it is classed as the ‘short’ type, suitable for 164 tooth manual flywheels, with the ring gear close to the back of the block, as indicated in the link that Jon1d has helpfully supplied.
    It doesn’t fit my 302 with a 157 tooth flywheel that has the ring gear fitted nearer to the clutch face of the flywheel - hence reason for sale.
    If you send me your email address or phone number in a PM I will send the original higher res photos.
    Regards, Martin.
    Jun 2005
    Huddersfield
    280
    Quote Originally Posted by blip View Post
    Regards, Martin.
    Sorry - I forgot to add that I took it off my previous engine that had the manual 164 tooth flywheel, so I know it definitely fits the 164 tooth, but will not fit 157 tooth.
    Regards, Martin.
    Jun 2005
    Huddersfield
    280
    Hi, now SOLD.
    Thanks for your interest.
    Regards, Martin.
