Results 1 to 8 of 8
    Lanarks
    267
    Corsa steering stalk wiring help
    Looking for a wiring diagram for the Corsa stalks Indicator/Horn/Wiper
    Have goggled wiring diagram but can't find anything on the Corsa
    Cobra now with a power steering column
    Lanarks
    267
    Solved
    Fitted classic BL Mini stalks to the Corsa column
    Lanarks
    267
    1,062
    What did you make the housing out of?
    Lanarks
    267
    GRP
    Underground drainage pipe used for the mould and modified so that it would slip over
    the column stalks
    Still to trim it for the angle and paint it to match the bodyshell
    Lanarks
    267
    And the cost to change over to Power Steering ?
    under £40
    Steering column £0 a great pal donated it
    Steel and welding rods to make the column support £0
    GRP £ 2 if that?
    Cataloy £0.50 if that
    Rubbing down paper £0.50 if that
    Paint £5 still got a near full can left
    Machining down the original Corsa steering wheel to make the adaptor £0
    BL wiper stalks £ 10
    e-bay electrical control box £ £20
    1,062
    That is a nice solution for the cowling. Wow you have managed to do that for a great budget. I know I am at about £500-£600 for all the parts so far including a new wooden steering wheel, boss adapter, mount kit steering, shaft mod, and still have stalks to add plus electronic controller. I am looking at my own electronic controller which should be automatic and progressive across the range. Project has stalled as I have other projects on the go so will do it as a rip out over winter project.
    Lanarks
    267
    New dash layout from my cheap and cheerful mould
    I never liked all those little warning lights all over the place spoiling the look.
    Hid my warning light cluster in the corner of the glove box - pointing at the driver.
