Results 1 to 10 of 19
    Jul 2010
    Chesterfield
    236
    Speedo Sensor Mounting
    Hi all,
    Looking for some help in where the best place to mount a sensor for the speedo would be.
    Recently had a speedo drive failure so invested in an electrical one which has the little LCD window for the odometer and trip.
    (my last one never had a trip)
    Just wondered if there was an easy place to mount the sensor on the jag back end, or any other place for that matter.
    I bet somebody will even have pics which would be really helpful as i'm sure i won't be the first to ask this.
    GD mk 3
    Cheers all.
    Ian
    May 2011
    Flimwell
    758
    I (and several others) have mounted the sensor close to the diff input flange bolt heads. Needs to be very close, 1 or 2mm, from the bolt heads. The bolts must be ferrous too.
    Hope that helps.
    Jul 2010
    Chesterfield
    236
    Thanks for that.Was this the bolts on the end of the prop shaft or the drive shaft.
    May 2011
    Flimwell
    758
    Has to be the prop shaft bolts. I will try to dig out and post a photo of mine.
    May 2011
    Flimwell
    758
    Colin
    Jul 2010
    Chesterfield
    236
    That's fantastic.
    A different shape to mine but I'm sure the principals the same.
    Never affected by water etc?
    Thanks for the post.
    May 2011
    Flimwell
    758
    Not affected by water. It’s completely sealed. Has a small LED light in it which flashes every time a bolt passes.
    3,741
    Really neat little sensor, that; did it come with a Speedo or on it's own? If the latter, can you remember where it came from?
    May 2011
    Flimwell
    758
    I bought all my instruments along with sensors/senders etc from Caerbont ( Smiths) in Wales.
    https://www.caigauge.com/
    Great after sales service and discount for club members.
    This sender is actually designed for use on motorbikes and yes it is very neat.
    I could dig out my paperwork and let people know the part number if anyone wants.
    3,741
    Ooh, I'll give them a bell.. I have a sensor, but it's the usual "barrel style" threaded sensor available from many places, and that one just looks so much neater and appears to come with its own bracket
    Have the gauges already - they came from Digital Speedos, but are Smiths gauges, so the sensor should be ideal. Thanks, Colin!
